AI Aircraft
BUDSCH
AI Aircraft
Post by BUDSCH »
I see that there are AI aircraft included with the purchase. How do I make them visible/operational?
Thanks for wonderful aircraft.
BUD
Re: AI Aircraft
Welcome BUDSCH!
There are several ways to use AI aircraft.
You can add them to AI flight plans or to user-created missions, nothing that would be straight forward to handle.
The easiest way to utilize them is by using Jerry Beckwith's formation utility, freeware available here:
http://www.mudpond.org/
Andreas
Re: AI Aircraft
Post by Andreas »
Talking about AI …
Those of you who use the AI aircraft, may notice that the propeller discs are black. (If you are close to the
aircraft) The way I found to solve the problem is the following:
Copy (the common propeller DDS file to the equivalent AI folder):
…\SimObjects\Airplanes\Classics_Hangar_Fw190A-1\texture\ch_prop_german.dds
to
…\SimObjects\Airplanes\Classics_Hangar_Fw190A_AI\texture
Best regards
Andreas
Re: AI Aircraft
Thank you, Andreas.
I never noticed that it's missing.
