Help With Starting The Plane
				tanker55
Hi:  I haven't been able to get the engine running after starting FSX.  I'm sure I'm just not doing it correctly.  I pump the fuel pressure handle until the left dial indicator raises to between the two small tooth like detents.  I give the primer two or three squirts, make sure the battery is on, magneto's to both, fuel cock on, throttle open a crack, and press the starter.  The properly turns, but the engine does not start.  Any suggestions.  It looks great, and I'm sure it will fly great as well once I figure out how to start the engine.  Thanks.  Mike Gutierrez, North Hollywood, California.
Re: Help With Starting The Plane
Hello Tanker,
try with just a single primer stroke initially and see if the engine starts.
Three strokes might be allready too many if you fly at warm weather (North Hollywood would indicate so, LOL)
				tanker55
Thanks for getting back to me so quickly.  I love your products and wish you much success.  Mike Gutierrez
Thank you!
Let me know if it works for you.
