Late Variants 1.22 not available
				alanngai
I had purchased my FW 190 Late Variants at the simMarket but I can't find any download link of the new 1.22 version, can you help? Thank you!
Re: Late Variants 1.22 not available
Both SimMarket and FS Pilot Shop should have the new files ready early in the coming week.
						- bmd
Hello Mathias
I have recceived an e-mail indicating that the Fw190 late variants version 11.22 was available on simarket. I was able to downloaded it and I will install it as soon as posssible. Thank you for the wonderrful Fw190 model.
Have a good day
Benoit
PS Can you rememeber us what are the modifications that come with this new vwesion 1.22?
Have a good day
Benoit
Hello Benoit,
below's the list of fixes for the late variants 1.22.
Mostly minor stuff but quite a lot of files affected and it became quite a bit confusing on the update pages, hence the recommendation to download again.
Revision 1.22
07. April 2010
Updates and fixes:
Just Fly Utlity is now part of the main installer.
Shortcut added to the start menu.
All exterior models:
Missing gear cover extension when bomb load is selected - fixed.
Missing radio antenna inside the canopy - fixed.
Fw190A-5 and Fw190A-5 MGFF exterior models:
Removed headrest support cables (introduced with the A-6).
Fw190A-5 MGFF exterior model:
Dublicated left wing geometry - fixed.
Fw190A-8/R2 Sturm and Fw190A-9:
Removed obsolete payload entries from aircraft cfg.
German language installation only:
Payloads on all aircraft A-7 to A-9 in English language - fixed.
Revision 1.22
07. April 2010
Updates and fixes:
