Fw190A early variants V.2 sneak peak
Just one shot of the new A-4 cockpit.
"Downgrade" over the late variants:
- Artificial horizon and AFN2 gone south
- turn coordinator back in
- main flight instruments moved around and covered with a plate
- fuel pump indicators in the lower forward panel.
					Last edited by Mathias Pommerien on Sat 13. Feb 2010, 19:33, edited 2 times in total.
Reason: Image removed, fresh images in Nick's post below.
				eddie
Re: Fw190A early variants V.2 sneak peak
Looks wonderful Mathias!!
				Huub Vink
New textures as well?
Updated exterior textures only, Huub, since there are a few areas remapped in the engine nacelle/wingroot.
That means in return that older third party repaints will no longer be compatible with the updated early variants.
The VC's of course are all new using the late variants artwork as the starting point.
A-3 and A-4 are basically complete.
Just a bit of re-programming to the systems to do.
				GAJIT
That all looks superb - well done
						- Nick C
I think I'm possibly duplicating shots, I should have taken a look at this forum post prior to taking more pictures.
- Nick C
I've just send the release candidate installer to the testers so we should be in for an early variants relaunch by the weekend.
