A little demo you can download here Mathias. Maybe you have an idea.
Clipping effect
- Basti_793
Re: Clipping effect
On my clean notebook without tweaked shaders and stock textures, I have also this effect.
				helitom
Re: Clipping effect
Moin Uwe,
die von Dir als Demo angebotene Datei ist eine zip-Datei, kann aber nicht geöffnet werden (bei mir)! Any idea?
Beste Grüße aus ETHB
Tom
Tom
Re: Clipping effect
The zip works for me, yet I can't dublicate the issue.
Uwe, with a similar zoom setting like in your video, do you get the same with stock planes or other third party aircraft?
- Basti_793
Re: Clipping effect
Mathias, I use a widescreen display and the Acceleration expansion pack. And yes, the clipping also occurs in some stock and other third party aircrafts from a height of 100ft AGL.
However, the effect doesn't visible with the Lotussim L-39 Albatros.
@ Tom ... Please download the file again. By uploading via UMTS from "far far away" problems was occurred. Sorry
Re: Clipping effect
Ah ok, so it seems to be an issue with some stock components, good to know!
The L-39 doesn't use effect lights but 3d lights which have other issues such as funky colored ground polygons and blocky display in foggy/cloudy weather conditions so it obviously isn't perfect either.
- Basti_793
Re: Clipping effect
Mathias, I'm back to my homebase in the middle of the next week (finally).
						- Basti_793
Re: Clipping effect
Ok, the problem is probably a bug in FSX. Here is another topic Mathias:
http://forum.avsim.net/topic/271462-pro ... s-fsx-mdl/ __
