Hello to all,
After installing this great plane i opened the right canopy with the lever on the aft side, but how can i close it again, is there a "hidden" clickspot? The original one is not reachable any more in the open state!
Best regards from ETHB
Thomas
						Closing canopy doors?
Re: Closing canopy doors?
Hello Thomas,
copy from another post on the subject:
The canopies and cargo door open with the usual command, Shift + E immedeatly followed by 1, 2 or 3.
However, due to the amount of code that's running in the background you need to hit the number very fast after the Shift+E, else there may be a refresh issue.
The default Shift+E (without number) will in any case operate the left canopy.
When in doubt you can move outside the plane using CTRL+Shift+Enter or CTRL+Shift+Backspace to move the viewpoint left/right until you can reach the handgrip.
CTRL+Space returns the viewpoint to default position.
				helitom
Hallo Mathias,
danke für die schnelle Antwort, bin ja neu hier und habe gerade das Forum durchblättert und genau diese Info´s gefunden! Ich bleibe dran und werde Dich bzgl. meiner Review für das FSMagazin sicher noch häufiger "belästigen".
Beste Grüße aus ETHB
Thomas
Thomas
