Unbreakable engine
X-RAY
Unbreakable engine
Post by X-RAY »
Hello,
Excuse my English, I hope that you will understand.
I've got the FW 190 the late variants V1.21.
Now, I can open the throttle at full power without engine problems. My realism settings are in the hardest possible. I don't understand,
Thank you for your help.
Re: Unbreakable engine
Hello X-RAY,
I suppose you did not install the "just fly" mod, right?
In default (hard) mode it depends on the aircraft how long it takes to damage the engine.
With the A-5 and A-6 it will take about 4 to 6 minutes.
With the A-7 and A-8 (which use the improved BMW801D-2 F600) it can take in excess of 10 minutes at full throttle.
The A-9 is very hard to damage at all.
The only way to instantly kill an engine is by giving full throttle to a cold engine when on the ground.
X-RAY
Post by X-RAY »
Hi Mathias,
Thank you so much for the answer.
The plane have no problem! It works very well.
thank you again!
Great then, enjoy the plane!
