Late Fw190A external models
Let's start with this one. These are entirely unedited shots, no color correction, no sharpening, no nothing.
The texturing is yet to receive some finishing touches.
Can you guess the sub version?
- 2009-6-18_13-41-9-769.jpg (89.25 KiB) Viewed 75333 times
- 2009-6-18_13-40-18-369.jpg (91.4 KiB) Viewed 75328 times
- 2009-6-18_13-39-25-895.jpg (226.1 KiB) Viewed 75332 times
SpitfiresBeatWulfs
Re: Late Fw190A external models
That's the A-7/R2 (the pitot tube isn't on the wing yet, but the gun is moved forwards) , but it looks like the bump under the cowling is missing?
In all the photos I have for the FW190, I see a small bump under the cowling right where it starts to curve into the prop, although less than 1/30th of FW190's were of the A7 type, so it may have been taken out in that variant.
Yep, it's an A-7/R2, but what do you mean by "guns moved fore"?.
You mean that little bulge under the nacelle aft of the oil cooler ring?
Hmm, thought it was too small a feature to model it.
Might add it, thanks for the suggestion.
BTW, what a funny screen name.
SpitfiresBeatWulfs
Well, it took a while, but it finally happened.Mathias Pommerien wrote:Yep, correct answer.
And by "Guns moved forward", I meant that between the A-6 and the A-7, the Maschinengewehr is further away from the canopy.
Last edited by SpitfiresBeatWulfs on Mon 22. Jun 2009, 01:00, edited 1 time in total.
Naa, not really, took them until the MkIV to pass by the A but that was when the Dora was the current fighter (well, almost).SpitfiresBeatWulfs wrote:Well, it took a while, but it finally happened.Mathias Pommerien wrote::
As for the nose gun, same location, different gun, Mg17 replaced by Mg131
SpitfiresBeatWulfs
Mathias Pommerien wrote:Naa, not really, took them until the MkIV to pass by the A but that was when the Dora was the current fighter (well, almost).SpitfiresBeatWulfs wrote:Well, it took a while, but it finally happened.Mathias Pommerien wrote::
Whoops, guess you're right, I was going by the placement of the guns apogee.
You all had the Dora... till the XIV came along!
BobSmall
It's the oil dump valve cover.Mathias Pommerien wrote:You mean that little bulge under the nacelle aft of the oil cooler ring?
On all A, F and Gs from the A-1 onwards.
Fw190A-4 Black 4 III/JG26 currently flying out of Hervey Bay (YHBA), Queensland, Australia
So here's your blister then....
- 2009-6-22_13-9-52-889.jpg (55.7 KiB) Viewed 75233 times
Of course I ment to say "Mk XIV" not "Mk IV".
SpitfiresBeatWulfs
Lookin' good
