I have just done a re-install of FSX and all the planes. Of course my favorite is the Fw 190.
I am trying to get the guns to work. I noticed that there is no ammo on the counters. I had this feature working before, but not now.
The switches are on and the trigger is set fot the carb heat "H", but nothing happens. I looked around for an answer but could not find a solution. Wht am I doing wrong?
Thanks for a great plane.
FW 190A ammo
Re: FW 190A ammo
Hi Steven,
you need Rob Barendregt's gun and cannon effects for the Fw190.
Search Avsim for rcbfw-20.zip and rcbfw20a.zip.
They where originally made for the early variants only but can be used with all models.
Below's the aircraft.cfg's light entries for all models.
Other than that install as per Rob's readme.
A-1 and Aa-3:
light.3 = 1, 1.9, -3.03, -1.1, FW190Cannon,
light.4 = 7, 2.3, -0.3, 2.3, FW190Cannon,
light.5 = 8, 2.3, 0.3, 2.3, FW190Cannon,
light.6 = 9, 1.9, 3.03, -1.1, FW190Cannon,
All A-2 to A-6 models:
light.3 = 1, 3.1, -3.03, -1.05, FW190Cannon,
light.6 = 9, 3.1, 3.03, -1.05, FW190Cannon,
A-7, A-7_R2, A-8, A-9:
light.3 = 1, 3.1, -3.03, -1.06, FW190Cannon,
light.4 = 7, 2.55, -0.427, 2.26, FW190Cannon,
light.5 = 8, 2.55, 0.427, 2.26, FW190Cannon,
light.6 = 9, 3.1, 3.03, -1.06, FW190Cannon,
A-8_R2:
light.3 = 1, 2.252, -7.734, -0.72, FW190Cannon,
light.4 = 7, 3.1, -3.03, -1.06, FW190Cannon,
light.5 = 8, 3.1, 3.03, -1.06, FW190Cannon,
light.6 = 9, 2.252, 7.734, 0.72, FW190Cannon,
A-1 and Aa-3:
A-8_R2:
Re: FW 190A ammo
Thanks
I thought that I had saved these as a backup, but not
