Hi Mike,
yes, exactly 0°.
Don't worry, the primer code is a bit static as is the engine failure code, since it was our first design back then.
I'm planning an update anyway sometime over the coming month to bring it up on par with our Bf108.
													Possible Solution for TW-Lock-, Startup-, Sound- Problems
				Mike6800
Re: Possible Solution for TW-Lock-, Startup-, Sound- Problems
Sounds great ! Though everything is fine now I'm really looking forward to the FW190 being on par with the bf108.
Thanks a lot and best regards,
Mike.
Mike.
AMD Phenom II X6 1090T/Gigabyte 890GPA-UD3H/8GBDDR3@1600/ATI Radeon HD 5850 /FSX w. Acceleration Pack/Windows 7 64bit SP1/FEX/TrackIR Pro4/AS2012
